Looking for a Lovable alternative for a small app build — what are people using?
I’m Laura, based in Reno and mostly just someone who likes learning new tools and reading about how other people approach projects. I’ve been looking into AI app builders and I keep running into Lovable, but I’m hesitant to commit to one platform without understanding the alternatives. My main concern is how much control I’d have over the generated code — I’m not a developer, but I’d rather not end up locked into something I can’t export or adjust later. I also want to know whether these tools hold up when a project grows past a simple prototype, or if people usually switch to something else at that point. I haven’t built anything yet, just comparing options and trying to work out what’s realistic for a beginner. For anyone who has moved from Lovable to another builder, what made you switch, and was the transition worth it? Any input from people who’ve actually used these tools would be helpful.
Update after reading more on this - Best Lovable Alternatives (2026) laid out several options with code export notes, which helps with my control worry. I’m still unsure whether these hold up past a prototype, so I’m not committing yet.
