Opening the Dashboard
After installing the lite node the public dashboard can be accessed if the note has been able to connect to the rest of the network and vice-versa.
To see the dashboard url run diode-node.info on your node which should provide output like this:
:~# diode-node.info
== Diode Node 0x090ad02cebd8fbbe0b411f5d870ab69d1004d6d8 ==
Version : 1.2.5
Uptime : 1357
Connected Devices: 0
Connected Peers : 6
Current Epoch : 664
Ticket Score : 0
Previous Epoch : 663
Ticket Score : 0
Dashboard : https://diode.io/network/#/node/0x090ad02cebd8fbbe0b411f5d870ab69d1004d6d8
Then follow the that dashboard URL. In the example above: https://diode.io/network/#/node/0x090ad02cebd8fbbe0b411f5d870ab69d1004d6d8
