Lite-Node Backup and Restore
For backup and restore of the lite-node installation the snap integration the is recommended way to go. https://snapcraft.io/blog/how-to-create-snapshots-of-your-snaps
Backup
The typical procedure looks like this:
# Step 1: flush any caches so they are not part of the backup:
> diode-node.flush
# Step 2: stop the node so the database is closed
> snap stop diode-node
# Step 3: the actual backup
> snap save diode-node
Set  Snap        Age    Version   Rev  Size    Notes
5    diode-node  764ms  v1.5.17   190  10.2MB  -
This last “Set” number is important as it will be prefix of a zip file created by snap. This backup zip file resides in /var/lib/snapd/snapshots on ubuntu systems. Top copy this to another machine.
Transfer
Let’s assume we have a new machine called newmachine.dev and it is reachable from the old machine. Then we can copy the file using scp from the old machine to the new one like this:
scp /var/lib/snapd/snapshots/5_diode-node*.zip newmachine.dev:
Restore
Finally to restore from the backup we install diode-node and use the backup zip file:
# Step 1: install diode-node
snap install diode-node
# Step 2: put the backup file into the snapshots directory
sudo cp 5_diode-node*.zip /var/lib/snapd/snapshots/
# Step 3: stop before applying the restore so no partial files are written
# (is is typically auto-started during installation)
# Step 4: actual data restore
snap restore 5 diode-node
# Step 5: restart the service
snap start diode-node
You can also:
Existing host
sudo diode-node.info
and note the “Diode Node 0xWALLETADRESS” wallet address
Then:
sudo diode-node.rpc 'IO.puts(DiodeClient.Base16.encode(DiodeClient.Wallet.privkey!(Diode.wallet())))'
This will output your private key to the console → copy the private key (e.g. 0xYOURKEY) that is shown and…
New host
sudo snap set diode-node private=0xYOURKEY && sudo snap restart diode-node.service && sleep 5 && diode-node.info
Then, confirm the wallet address on the new host matches your old host.
NOTE: This DOES NOT copy the tickets over, it only allows you to retain the same wallet when moving hosts…
