Folder not created on snap installation
dne-250301-saopaulo-02:~$ sudo snap install diode-node --edge
diode-node (edge) v1.8.4-1-ga0e34cd from Diode Labs installed
dne-250301-saopaulo-02:~$ sudo diode-node.info
--rpc-eval : RPC failed with reason :noconnection
** (ArgumentError) errors were found at the given arguments:
* 1st argument: no persistent term stored with this key
:persistent_term.get(Db.Creds)
(diode 1.8.4) lib/model/sql.ex:9: Model.Sql.map_mod/1
(diode 1.8.4) lib/model/sql.ex:50: Model.Sql.query/3
(diode 1.8.4) lib/model/sql.ex:69: Model.Sql.query!/3
(diode 1.8.4) lib/model/sql.ex:81: Model.Sql.lookup!/4
(diode 1.8.4) lib/model/sql.ex:74: Model.Sql.fetch!/3
(diode 1.8.4) lib/model/credsql.ex:72: Model.CredSql.ensure_config/2
(diode 1.8.4) lib/model/credsql.ex:52: Model.CredSql.ensure_identity/0
dne-250301-saopaulo-02:~$ diode-node.info
cat: /home/hansrempel/snap/diode-node/473/node: No such file or directory
=ERROR REPORT==== 12-Jan-2026::18:56:35.188383 ===
inet_config: file /home/hansrempel/snap/diode-node/473/erl_inetrc not found
dne-250301-saopaulo-02:~$ sudo snap logs diode-node
2026-01-12T19:00:05Z diode-node.service[2292046]: (stdlib 6.2.2) gen_server.erl:2184: :gen_server.init_it/6
2026-01-12T19:00:05Z diode-node.service[2292046]: (stdlib 6.2.2) proc_lib.erl:329: :proc_lib.init_p_do_apply/3
2026-01-12T19:00:07Z diode-node.service[2292046]: Kernel pid terminated (application_controller) (“{application_start_failure,diode,{{shutdown,{failed_to_start_child,‘Elixir.Exqlite.LRU’,{{badmatch,{error,<<\“unable to open database file (errno: 2)\”>>}},[{‘Elixir.Exqlite.LRU’,init,1,[{file,\“lib/exqlite/lru.ex\”},{line,26}]},{gen_server,init_it,2,[{file,\“gen_server.erl\”},{line,2229}]},{gen_server,init_it,6,[{file,\“gen_server.erl\”},{line,2184}]},{proc_lib,init_p_do_apply,3,[{file,\“proc_lib.erl\”},{line,329}]}]}}},{‘Elixir.Diode’,start,[normal,]}}}”)
2026-01-12T19:00:07Z diode-node.service[2292046]: Crash dump is being written to: erl_crash.dump…done
2026-01-12T19:00:07Z systemd[1]: snap.diode-node.service.service: Main process exited, code=exited, status=1/FAILURE
2026-01-12T19:00:07Z systemd[1]: snap.diode-node.service.service: Failed with result ‘exit-code’.
2026-01-12T19:00:07Z systemd[1]: snap.diode-node.service.service: Consumed 17.253s CPU time.
2026-01-12T19:00:07Z systemd[1]: snap.diode-node.service.service: Scheduled restart job, restart counter is at 30.
2026-01-12T19:00:07Z systemd[1]: Started snap.diode-node.service.service - Service for snap application diode-node.service.
The path creation issue on new installs has been fixed in v1.8.5rolling out now via edge.
