Diode VPN and Exit Nodes
Hey Community,
we have released Diode VPN the first standalone VPN client using the Diode Network. It is using the new wireguard compatibility layer to provide a simple consumer VPN that can be used with any app. This is similar to what ProtonVPN or NordVPN provide but permission-less and any node operator can become a participant earning from the fleets traffic.
To enable your node to become and exit node for wireguard traffic you just have to issue these additional snap commands:
sudo snap connect diode-node:network-control
sudo snap connect diode-node:firewall-control
sudo snap restart diode-node.service
These will allow the diode-node to auto-configure firewall and wireguard rules and become an exit node. After this is done you will see your own node appear on the map inside the Diode VPN app!
Cheers!
The firewall-control and network-control permissions are the part I’d want to understand better before granting them on a node I run, since auto-configuring wireguard and firewall rules is a fairly wide remit. I’m also unsure how exit-node traffic is attributed and what happens if a node drops mid-session. As a Portland user who mostly tinkers with small home setups, I’d probably test on a spare machine first rather than my main box. I did see DeepMind AI formally verifies Signal protocol in four weeks which got me thinking about how much protocol assurance matters for VPN layers. Has anyone run an exit node long enough to judge stability?
