After several researches regarding CGNAT in Brazil, I reached a conclusion. Here is below:
There are clear reasons why Brazilian companies still prefer to use IPv4 with CGNAT (Carrier-Grade NAT) instead of migrating to IPv6. I will explain the main reasons:
1. IPv4 Address Shortage
• IPv4 has a limit of 4.3 billion possible IP addresses. This stock has been depleted globally for years. In Brazil, due to the growing demand for internet connections (mobile devices, IoT, etc.), there is a significant shortage of IPv4 addresses.
• Solution with CGNAT: To circumvent the shortage of IPv4 addresses, operators implement CGNAT, a technique that allows multiple clients to share a single public IPv4 address. This saves addresses, but brings performance issues and limitations for users who need specific ports open, such as in the case of blockchain nodes and game servers.
2. Cost and Complexity of Migration to IPv6
• Although IPv6 was created to solve the IPv4 scarcity problem (with 3.4 x 10^38 possible addresses), many companies still hesitate to adopt IPv6 due to:
• Implementation costs: The migration to IPv6 can be complex and expensive. It involves updating network equipment, routers, and legacy systems that still do not support IPv6.
• Compatibility: Many old systems and devices were not designed to support IPv6. The transition may require hardware replacements and software adjustments, which increases the cost and complexity.
3. Lack of Economic and Regulatory Incentives
• In Brazil, there is no regulation that requires operators to migrate to IPv6. Moreover, the majority of residential customers and small businesses do not require IPv6, which means that, for telecommunications companies, the investment in IPv6 infrastructure does not yield an immediate return.
• CGNAT is cheaper in the short term: Maintaining IPv4 with CGNAT is more economical for companies than fully migrating to IPv6.
4. Low Adoption of IPv6 by End Users
• Even though many large services (Google, Facebook, etc.) already support IPv6, most end users still access the internet using IPv4. This creates a cycle of low adoption:
• Low demand: Since few users utilize IPv6, companies do not see urgency in implementing full support for IPv6.
5. Perceived Performance and Security Issues
• Some companies incorrectly believe that IPv6 may introduce security or performance issues, as IPv4 and its protection mechanisms (such as NAT) are more well-known and tested.
• Lack of Knowledge: The absence of knowledge on how to correctly configure and manage IPv6 networks also hinders adoption.
Current Situation and Perspectives
The adoption of IPv6 has been slowly increasing in Brazil, especially among major providers like Claro and TIM, which are already implementing dual-stack support. (IPv4 e IPv6). However, for smaller providers and some regions, the use of IPv4 with CGNAT is still the norm.
The transition to IPv6 is inevitable, but it may take time for all providers to widely adopt the technology. Some steps that could accelerate this include:
Regulation: Incentives or regulations that require IPv6 support.
Education: Increase in training and knowledge about IPv6 among network administrators.
Market pressure: With the increase in IoT devices and the demand for more simultaneous connections, the pressure to adopt IPv6 may grow.
